ASUS Z170-E
One click for superb performance, with USB 3.1 support
  • 5-Way Optimization: One click to optimize your entire system; plus a dedicated onboard water-pump header
  • ASUS Pro Clock Technology: Extends base clocks and improves stability for extreme overclocking
  • Crystal Sound 2, Intel LAN and Turbo LAN: Flawless audio and low-latency networking
  • USB 3.1 onboard: One reversible Type-C port
  • 5X Protection II: Advanced hardware safeguards
  • CPU
    Supports Intel® 14 nm CPU
  • Chipset
    Intel® Z170
  • Memory
    4 x DIMM, Max. 64GB, DDR4 3466(O.C.)/3400(O.C.)/3333(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
  • Graphic
    Multi-VGA output support : HDMI/DVI-D ports
    Supports up to 2 displays simultaneously
  • Multi-GPU Support
    Supports NVIDIA® 2-Way SLI™ Technology
    Supports AMD 2-Way CrossFireX Technology
  • Expansion Slots
    2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
    1 x PCIe 3.0/2.0 x16 (x2 mode)
    1 x PCIe 3.0/2.0 x1
  • Storage
    Intel® Z170 chipset :
    1 x SATA Express port, , Compatible with 2 x SATA 6.0 Gb/s ports
    1 x M.2 x4 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode)*1
    6 x SATA 6Gb/s port(s), gray
    Support Raid 0, 1, 5, 10
    Supports Intel® Smart Response Technology*2
  • LAN
    Intel® I219V, 1 x Gigabit LAN Controller(s), Dual interconnect between the Integrated Media Access Controller (MAC) and Physical Layer (PHY)
    Gigabit Intel® LAN Connection- 802.3az Energy Efficient Ethernet (EEE) appliance
    ASUS Turbo LAN Utility
    ASUS LAN Guard
  • Audio
    Realtek® ALC887 8-Channel High Definition Audio CODEC featuring Crystal Sound 2
    - Supports : Jack-detection, Multi-streaming, Front Panel MIC Jack-retasking
    Audio Feature :
    - LED-lit Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference, with a gorgeous illuminated trace path
    - Unique de-pop circuit: Reduces start-up popping noise to audio outputs
    - Top notch audio sensation delivers according to the audio configuration
    - Absolute Pitch 192khz/24bit true BD lossless sound
    Separate layer for left and right track, ensuring both sound deliver equal quality
  • USB Ports
    6 x USB 3.0/2.0 port(s) (2 at back panel, blue, 4 at mid-board)
    6 x USB 2.0/1.1 port(s) (2 at back panel, , 4 at mid-board)
    ASMedia® USB 3.1 controller :
    1 x USB 3.1/3.0/2.0 port(s) (1 at back panel, )
  • Special Features
    OC Design - ASUS PRO Clock Technology
    - Full BCLK range for extreme overclocking performance
    5-Way Optimization by Dual Intelligent Processors 5
    - Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ Power Control, Fan Xpert 3, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
    ASUS 5X Protection II :
    - ASUS DIGI+ VRM - 4 Phase digital power design
    ASUS TPU :
    - Auto Tuning
    - GPU Boost
    ASUS EPU :
    - EPU
    ASUS Digital Power Design :
    - Industry leading Digital 4 Phase Power Design
    - CPU Power Utility
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger+
    - Anti-Surge
    - USB 3.1 Boost
    - Turbo LAN
    - Crystal Sound 2
    - EZ XMP ASUS Exclusive Features
    - Mobo Connect
    - PC Cleaner
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit *3
  • Back I/O Ports
    1 x DVI-D
    1 x HDMI
    1 x LAN (RJ45) port(s)
    1 x USB 3.1 Type-C
    2 x USB 3.0 (blue)
    2 x USB 2.0
    6 x Audio jack(s)
  • Internal I/O Ports
    2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
    1 x SATA Express connector: , Compatible with 2 x SATA 6.0 Gb/s ports
    1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
    1 x COM port(s) connector(s)
    6 x SATA 6Gb/s connector(s)
    1 x CPU OPT Fan connector(s) (1 x 4 -pin)
    1 x S/PDIF out header(s)
    1 x Thunderbolt header(s)
    1 x System panel(s)
    1 x 5-pin EXT_FAN(Extension Fan) connector
    1 x DRCT header(s)
    1 x MemOK! button(s)
    1 x Clear CMOS jumper(s)
    1 x Water Pump header (4-pin)
    1 x 14-1 pin TPM connector
  • Accessories
    User's manual
    I/O Shield
    1 x M.2 Screw Package
    1 x CPU installation tool
    1 x Supporting DVD
    1 x SLI bridge(s)
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    EZ Update
  • Form Factor
    ATX Form Factor
    12.0 inch x 9.2 inch ( 30.5 cm x 23.4 cm )
  • Note
    *1: M.2 shares SATA mode with SATA Express. Change this item before installing M.2 SATA devices.
    *2: These functions will work depending on the CPU installed.
    *3: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
boardview
ASUS Z170-E REV1.01A.fz
ASUS Z170-E REV1.01.fz
Z170-E-ASUS-3801.zip
