BIOS above not same ?request bios Feilong MB REV : 1.03 B
yess, this bios not displayBIOS above not same ?
it display has many other problems, if it has the same problem with Original bios then this is not biosyess, this bios not display
i have changed the CPU, do you have a different bios? or can you rebuild the original bios?it display has many other problems, if it has the same problem with Original bios then this is not bios
please rebuildreplacing the laptop CPU still has a normal display, no other BIOS programming is required and it has no effect on builds because it is the same
ad buil giup em, bios k load ram
