toshiba password not in BIOS
try this
All f
rom 2012 to 2017
Note: The Challenge and Response Code makes it possible to bypass the
BIOS password. Clearing must be done in the System Setup (BIOS).
Switch on the
notebook , when the boot logo appears press [F2].
"Password=" will be display.
Press keys in the order [CTRL], [TAB], [CTRL] and [ENTER].
The Serial number and Challenge code will be displayed.
Take a picture of it, and send to me
Please do not mix up "0" and "O" or "C" and "G" or "8" and "B".
IMPORTANT :
Do not switch off the laptop or restart, cause response code ll change, NO REFUND if so
You will receive the "Response code"
Enter the Response code (do not mix up "0" and "O" or "C" and "G" or "8" and "B")
and press [ENTER] key.
The "TOSHIBA Setup Utility" (BIOS) appears.
Go to the "Securtiy" tab by pressing the cursor right key [->].
Check if the line "User Password Registered" is marked.
Press [ENTER] then [space bar] and [ENTER] key three times to set the password to "Not Registered".
Press [F10] key to save the changes and confirm this by pressing the [Y] key.
The BIOS Password is deleted.
Press F2 go bios setting and enter agian this code then
unlock remember
