Asus TROOPER B150 D3
ASUS TROOPER B150 D3
BIOS TROOPER-B150-D3-ASUS-0212 16MB
Best-value TUF B150 ATX board with military-grade components and cooling tech to guarantee 24/7 durability
  • TUF Certified 24/7 durability - Promised Reliability with Strict Testing
  • TUF LANGuard - Exclusive military-grade LAN protection
  • TUF ESD Guards 2 - 2X Stronger ESD protection for extended component lifespan
  • TUF Audio Design– LED-lit shielding and noise reduction
  • TUF Thermal Radar Core - Complete System Cooling, Customized Fan Tuning
  • TUF Components [Caps, Chokes & MOSFETs; Certified by Military-standard] – Certify for Tough Duty
  • CPU
    Supports Intel® 14 nm CPU
    * Refer to www.asus.com for CPU support list
  • Chipset
    Intel® B150
  • Memory
    2 x DIMM, Max. 32GB, DDR3 1600/1333 MHz Non-ECC, Un-buffered Memory
    * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
  • Graphic
    Integrated Graphics Processor
    Multi-VGA output support : DVI/RGB ports
    - Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
  • Multi-GPU Support
  • Expansion Slots
    1 x PCIe 3.0/2.0 x16
    1 x PCIe 3.0/2.0 x16 (x1 mode, black)
    1 x PCIe 3.0/2.0 x16 (max at x4 mode, black)
    2 x PCIe 3.0/2.0 x1
  • Storage
    Intel® B150 chipset :
    6 x SATA 6Gb/s port(s), black,
    Intel® Rapid Storage Technology supports
  • LAN
    Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
  • Audio
    Realtek® ALC887 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
    Audio Feature :
    - LED-lit Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference, with a gorgeous illuminated trace path
    Separate layer for left and right track, ensuring both sound deliver equal quality
  • USB Ports
    6 x USB 3.0/2.0 port(s) (4 at back panel, blue, 2 at mid-board)
    6 x USB 2.0/1.1 port(s) (4 at back panel, black, 2 at mid-board), 2 port(s) supports USB Over-Voltage Protection
  • Special Features
    TUF ENGINE! Power Design :
    - 3 +2 Digital Phase Power Design
    - TUF Components (Choke, Cap. & MOSFET; certified by military-standard)
    - ASUS DIGI+ VRM Utility
    Ultimate COOL! Thermal Solution :
    - TUF Thermal Radar Core
    Safe & Stable! Guardian Angel :
    - TUF ESD Guards 2
    - TUF LANGuard
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger
    - USB 3.0 Boost
    - Disk Unlocker
    ASUS EZ DIY :
    - ASUS O.C. Profile
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - Multi-language BIOS
    ASUS Q-Design :
    - ASUS Q-Slot
    - ASUS Q-DIMM
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit
  • Back I/O Ports
    1 x PS/2 keyboard (purple)
    1 x PS/2 mouse (green)
    1 x DVI
    1 x D-Sub
    1 x LAN (RJ45) port(s)
    4 x USB 3.0 (blue)
    4 x USB 2.0
    3 x Audio jack(s)
  • Internal I/O Ports
    1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, beige)
    1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
    1 x COM port(s) connector(s)
    6 x SATA 6Gb/s connector(s)
    2 x Chassis Fan connector(s) (2 x 4 -pin, [Black])
    1 x S/PDIF out header(s)
    1 x System panel(s)
    1 x Chassis Intrusion connector(s)
    1 x DRCT header(s)
    1 x CPU OV
    1 x Clear CMOS jumper(s)
    1 x 14-1 pin TPM connector
  • Accessories
    User's manual
    I/O Shield
    2 x SATA 6Gb/s cable(s)
    1 x TUF Certification card(s)
    1 x TUF 5 Year Warranty manual(s) (by region)
    1 x TUF Inside sticker(s)(white)
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    ASUS/TUF CPU-Z
  • Form Factor
    ATX Form Factor
    12 inch x 7.1 inch ( 30.5 cm x 19.8 cm )
TROOPER-B150-D3-ASUS-0212.BIN.zip
