SUPRA LED
Model: STV-LC16500WL
Chassis/Version: TP.VST59.P67
Panel: B156XTN03.2
MainBoard: TP.VST59.P67
IC MainBoard: CPU TSUMV59XE-Z1, Flash W25Q32FVSIG
Brand : AUO
Model : B156XTN03.2 1 Compatible model
Type : a-Si TFT-LCD, Panel
Diagonal size : 15.6 inch
Resolution : 1366x768, WXGA
Display Mode : TN, Normally White, Transmissive
Active Area : 344.232x193.536 mm
Shape Style : Slim (PCBA Flat, Depth ?3.2mm)
Surface : Glare (Haze 0%), Hard coating (3H)
Brightness : 200 cd/m²
Contrast Ratio : 500:1
Display Colors : 262K (6-bit), CIE1931 45%
Response Time : 2/6 (Tr/Td)
Frequency : 60Hz
Lamp Type : WLED Embedded (LED Driver)
Signal Interface : LVDS (1 ch, 6-bit), 40 pins
Voltage : 3.3V
Panel: B156XTN03.2
Brand : AUO
Frequency : 60Hz
Voltage : 3.3V
U8 W25Q32FVSIG Supra STV-LC16500WL V1N04.bin
