Miix 320-10ICR Tablet (ideapad) BIOS
BM5668_V1P4
5hcn37ww
BM5668_V1P4
5hcn37ww
Miix 320-10ICR Tablet (ideapad) 5hcn37ww.BIN.zip
Please need to remove the bios passwordMiix 320-10ICR Tablet (ideapad) BIOS
5hcn37ww
Hi sir,i flash with the bin is on the top but the pc is blinking,i reflash with the original but again is blinking,please any solution?Miix 320-10ICR Tablet (ideapad) BIOS
BM5668_V1P4
5hcn37ww
new and old you same problem ? you need check tool ProgrammingHi sir,i flash with the bin is on the top but the pc is blinking,i reflash with the original but again is blinking,please any solution?
Both of bin do the same,just blink,the programmer working ok,i test,and the adaptor 1.8 volt is ok,maby any resistor is damaged?do you have the schematics for this model please?new and old you same problem ? you need check tool Programming
programmer working but returm old same not working. Hardware has broken when you remove chip, only you can checkBoth of bin do the same,just blink,the programmer working ok,i test,and the adaptor 1.8 volt is ok,maby any resistor is damaged?do you have the schematics for this model please?
1.8v is a programming tool issue and adapter is not related to the BIOSMaby need to rewrite the chip with the adapter 1.8volt Sir?
remove the password Please
clear me bios password plz
So need to buy patch 25 $the password still exist sir!!!
curare Unavailablesir need schmatic and boardview of bm5668_v1p4_r_n
