HP ENVY X360 2-IN-1 LA-m023p BIOS
add build giúp file này nhé. cám ơn
cám ơn add, file gốc kích nguồn còn lên, file này tịt nguồn luôn rồi
AMD thì nạp bios khác vẫn thế thì do chipsetnháy caplock 5 dài 3 ngắn thuòng là bị gì vậy a
AMD need try BIOS this and check hardwareHi,
Can you please rebuild this BIOS? Capslock gives 5 long and 3 short blinks, nothing displays.
Thank you.
Still no boot, but with your BIOS it doesn't blink 5-3 anymore, just powers on and then off after 3 seconds, so your BIOS might be good, but It's possible that there's just another problem with the board. Either way, I'm done with this one, found a cheap working motherboard that I can buy.AMD need try BIOS this and check hardware
HP ENVY x360 15.6 inch 2-in-1 Laptop PC 15-ey0000 (54J83AV) 08a31_DMI AMD.bin.zip
check AMD chipsetStill no boot, but with your BIOS it doesn't blink 5-3 anymore, just powers on and then off after 3 seconds, so your BIOS might be good, but It's possible that there's just another problem with the board. Either way, I'm done with this one, found a cheap working motherboard that I can buy.
Thank you!
check AMD chipset
