HP 280 Pro G5 Microtower PC BID 086E9
HP 280 Pro G5 Microtower PC BID 086E9.bin.zip
Mình cần Bios HP 280 Pro G5 Small Form TH10 ( con này nhỏ hơn MicroTower chút), P/N: M99164-001.
Máy mình kích nguồn không lên hình, kêu 3 bíp dài 2 bíp ngắn. Pro nào có bios hoặc fix giúp mình nhé, thanks
Clear me
intermidate display
build this
Good morning, I have this bios with a corrupt error, I have placed several bios in it and they all get the same error, please help me, model hp 280 g5, model main board bakerms rev: A , M11
old bios same problem ?The bios you sent shows the same error as the previous bios, please help me.
yes the same problemold bios same problem ?
If all bios have the same problem then you need to buy the $22 patchHello, what do I do, I've been waiting for a response for a while, thank you
THEN WHY POST THOSE BIOS, IF YOU KNOW THEY HAVE THE SAME PROBLEMIf all bios have the same problem then you need to buy the $22 patch
I also sent the BIOS to you and you said it couldn't be solved and other people did the same thing. Can you ask them if they can solve it?THEN WHY POST THOSE BIOS, IF YOU KNOW THEY HAVE THE SAME PROBLEM
