HMK-G41A HTM265 rev3.0
HT265H03
HT265H03
HT265H03.ROM.zip
Hi. I need other bios dump for HMK-G41A HTM265 rev3.0.HMK-G41A HTM265 rev3.0
HT265H03
no Understand. bios above have problem what ?Hi. I need other bios dump for HMK-G41A HTM265 rev3.0.
Can u help me ?
problem other is problem what ?Motherboard HMK-G41A HTM265 rev3.0
When i use your dump for rev 3, USB ports not working
And when I use this dump for rev 1 USB ports working but have other problems.
When I use rev 1 dump, board working only with one power supply Xlilence ) and not other one/problem other is problem what ?
all bios I provided above same problem ? machine work have display ?When I use your HTM265 1.0 GD25Q80 HMK-G41 and HT265H03.ROM.zip dump USB have a 4.7V.
And when I use my bios dump HMK_HTM265 _rev_1_OK USB have a 5.1V and USB flash or mouse/keyb are working.
But works only with one power supply unit
HT265H03.ROM.zip dump have display but USB VCC 4.7V and keyb/mouse/ flash not workingall bios I provided above same problem ? machine work have display ?
I think you need check again hardware.HT265H03.ROM.zip dump have display but USB VCC 4.7V and keyb/mouse/ flash not working
I have a dump for rev 1/ When I use this dump USB vcc 5V, have display, OC working good (W7) but working only with one power supply Xilence 450W - not other one
