Ask HELP ASUS G513R 6050A3348803-MB-A02 Reboot pluging m2
Question & Answer Forums
pedidosrma@pccomponentes.
I have an ASUS G713R / INVENTEC G513R – 6050A3348803-MB-A02.
The laptop powers on and enters the BIOS normally, everything works fine. However, when I connect an SSD to either of the two M.2 slots, the laptop immediately restarts.
I have checked all the main power rails and everything seems normal. The SSDs are good — I tested them in another machine. I also tested three different NVMe SSDs, and the behaviour is exactly the same.
I have boardview available, but there is no schematic for this board.
Does anyone have any suggestions on what I should check next?
I managed to boot the system from USB and entered HBCD without any issues.
After further analysis, we concluded that the problem is likely related to the M.2 controller integrated into the CPU.
We will return the unit to the customer.
Please close the topic.
Thank you everyone for the support.
CAN YOU SHARE FILE BOARDVIEW SIR. PLS
