I think you need check AMD chipcan you helpme this file wont work and with your bin is balack screen can you rebuild this
it shows bios updating and reboots an then seems like its turning on without backlight repeatidly any suggestionI think you need check AMD chip
I said the above suggestionI think you need check AMD chip
thanksI think you need check AMD chip
HAGRID20-6050A3178801-MB-A01 - 085B1 BIOS after flashing your bios
Same in my caseI said the above suggestion
I tried it. Once display show bios flashing but restart no display with flicker!try this
buildse3.zip
old bios error what ?I tried it. Once display show bios flashing but restart no display with flicker!
no display with flicker.old bios error what ?
send I check BIDno display with flicker.
ORIGINAL BIOSsend I check BID
ORIGINAL BIOS
bb.zipthis bios no display plz builds this bios
bb.zipHola esta bios solo el ventilador sube y baja velocidad y apaga y enciende led blanco y se mantiene pantalla negra, ayuda por favor.
