Asus H170M-E D3
ASUS H170M-E D3
BIOS H170M-E-D3-ASUS-0601 16MB
Great-value micro-ATX H170 with 5X Protection II for dependable stability, DDR3/DDR3L memory compatibility, and UEFI BIOS with EZ Flash 3
  • 5X Protection II – Advanced hardware safeguards for all-round protection
  • DDR3/DDR3L memory compatibility
  • Lightning-fast M.2 with PCIe® 3.0 x4 interface
  • Epic gaming audio with noise-isolation design
  • Media-acclaimed UEFI BIOS with EZ Flash 3
  • Easy PC DIY with safe motherboard-mounting design
  • Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
  • CPU
    Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
    Supports Intel® 14 nm CPU
    * Refer to www.asus.com for CPU support list
  • Chipset
    Intel® H170
  • Memory
    4 x DIMM, Max. 64GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
    * The maximum memory frequency supported varies by processor.
  • Graphic
    Multi-VGA output support : HDMI/DVI-D/RGB ports
    Supports up to 3 displays simultaneously
  • Multi-GPU Support
    Supports AMD 2-Way CrossFireX Technology
  • Expansion Slots
    1 x PCIe 3.0/2.0 x1 (x16 mode, gray)
    1 x PCIe 3.0/2.0 x1 (max at x4 mode, black)
    1 x PCIe 3.0/2.0 x1
    1 x PCI
  • Storage
    Intel® H170 chipset :
    4 x SATA 6Gb/s port(s), gray,
    1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
    Support Raid 0, 1, 5, 10
    Supports Intel® Smart Response Technology
  • LAN
    Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
  • Audio
    Realtek® ALC887-VD2 8-Channel High Definition Audio CODEC *2
    - Supports : Jack-detection, Front Panel Jack-retasking
    Audio Feature :
  • USB Ports
    8 x USB 3.0/2.0 port(s)
    6 x USB 2.0/1.1 port(s)
  • Special Features
    ASUS EPU :
    - EPU
    ASUS Exclusive Features :
    - GPU Boost *3
    - AI Suite 3
    - Ai Charger
    - Anti-Surge
    - Low EMI Solution
    - USB 3.0 Boost
    - Mobo Connect
    - PC Cleaner
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert 2+
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - ASUS UEFI BIOS EZ Mode
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Slot
    - ASUS Q-DIMM
    Media Streamer
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit *3
  • Back I/O Ports
    1 x PS/2 keyboard (purple)
    1 x PS/2 mouse (green)
    1 x DVI-D
    1 x D-Sub
    1 x HDMI
    1 x LAN (RJ45) port(s)
    4 x USB 3.0 (blue)
    2 x USB 2.0
    3 x Audio jack(s)
  • Internal I/O Ports
    2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin, blue)
    1 x M.2 Socket 3 for M Key, type 2242/2260/2280 devices
    1 x LPT header
    1 x COM port(s) connector(s)
    4 x SATA 6Gb/s connector(s)
    1 x S/PDIF out header(s)
    1 x System panel(s)
    1 x Clear CMOS jumper(s)
    1 x 14-1 pin TPM connector
  • Accessories
    User's manual
    I/O Shield
    2 x SATA 6Gb/s cable(s)
    1 x M.2 Screw Package
    1 x Supporting DVD
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
    ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    ASUS EZ Update
  • Form Factor
    uATX Form Factor
    9.6 inch x 8.8 inch ( 24.4 cm x 22.4 cm )
  • Note
    *1: These functions will work depending on the CPU installed.
    *2: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
    *3: The function supported varies by processor.
    *4: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
H170M-E-D3-ASUS-0601.bin.zip
