H170I-PLUS D3
BIOS H170I-PLUS-D3-ASUS-0403 16MB
Supreme mini-ITX H170 with onboard 802.11ac Wi-Fi, M.2 transfer, and 5X Protection II for dependable stability
- 5X Protection II – Advanced hardware safeguards for all-round protection
- DDR3/DDR3L memory compatibility
- 2x2 Dual-Band 802.11ac + BT4.0 connectivity
- Media-acclaimed UEFI BIOS with EZ Flash 3
- Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
- Lightning-fast M.2 with PCIe® 3.0 x4 interface
- CPU
Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
Supports Intel® 14 nm CPU
- Chipset
Intel® H170 - Memory
2 x DIMM, Max. 32GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
* To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V. - Graphic
Multi-VGA output support : HDMI/DVI-D/RGB/DisplayPort ports
- Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
Supports up to 3 displays simultaneously - Expansion Slots
1 x PCIe 3.0/2.0 x16 - Storage
Intel® H170 chipset :
1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
4 x SATA 6Gb/s port(s) - LAN
Intel® I219V, 1 x Gigabit LAN Controller(s) - Wireless Data Network
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Support ASUS Wi-Fi Go! Utility - Bluetooth
Bluetooth V4.0 - Audio
Realtek® ALC887 7.1-Channel High Definition Audio CODEC *1
- Supports : Jack-detection, Front Panel Jack-retasking - USB Ports
8 x USB 3.0/2.0 port(s) (6 at back panel, blue, 2 at mid-board)
4 x USB 2.0/1.1 port(s) (4 at mid-board) - Special Features
ASUS 5X Protection II :
- ASUS DIGI+ VRM - 6 Phase digital power design
- ASUS ESD Guards - Electrostatic discharge protection
ASUS EPU :
ASUS Exclusive Features :
- AI Suite 3
- Ai Charger
- Anti-Surge
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2+
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS UEFI BIOS EZ Mode
- Push Notice
ASUS Q-Design :
- ASUS Q-DIMM
Media Streamer - Operating System Support
Windows® 10 , 64bit
Windows® 8.1 , 64bit
Windows® 7 , 32bit/64bit *2 - Back I/O Ports
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
6 x USB 3.0 (blue)
1 x Optical S/PDIF out
3 x Audio jack(s)
1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0 - Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, blue)
1 x SATA Express connector: , Compatible with 2 x SATA 6.0 Gb/s ports
1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Internal speaker connector(s)
1 x System panel(s)
1 x Clear CMOS jumper(s)
1 x 14-1 pin TPM connector - Accessories
User's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x Supporting DVD
1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant) - BIOS
128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information - Manageability
WfM 2.0, DMI 3.0, WOL by PME, PXE - Support Disc
Drivers
ASUS Utilities
ASUS EZ Update
- Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm ) - Note
*1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
*2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
H170I-PLUS-D3-ASUS-0403.BIN.zip
