Asus EX-B150M-V5 D3
ASUS EX-B150M-V5 D3
BIOS EX-B150M-V5-D3-ASUS-0406 16MB
ASUS EX-B150M-V5 D3 RG.pdf
  • CPU
    Supports Intel® 14 nm CPU
  • Chipset
    Intel® B150
  • Memory
    2 x DIMM, Max. 32GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
    * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
  • Graphic
  • Expansion Slots
    1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
    2 x PCIe 3.0/2.0 x1
  • Storage
    Intel® B150 chipset :
    4 x SATA 6Gb/s port(s), gray,
  • LAN
    Realtek® 8111GR, 1 x Gigabit LAN Controller(s)
    ASUS LAN Guard
  • Audio
    Realtek® ALC887 8-Channel High Definition Audio CODEC featuring Crystal Sound 2*1
    - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • USB Ports
    6 x USB 3.0/2.0 port(s) (4 at back panel, , 2 at mid-board)
    6 x USB 2.0/1.1 port(s) (4 at back panel, blue, 2 at mid-board), 2 port(s) supports USB Over-Voltage Protection
  • Special Features
    ASUS 5X Protection II :
    - ASUS DIGI+ VRM - 7 Phase digital power design
    Non-stop Durability :
    - Anti-moisture coating - Outstanding protection against moisture and corrosion
    - USBGuard- 120% higher voltage tolerance
    - Anti-theft memory - Locked-down memory for everyday security
    Non-stop Gaming :
    - LED-lit Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference, with a gorgeous illuminated trace path
    - Audio amplifier: Provides the highest-quality sound for headphone and speakers
    - Unique de-pop circuit: Reduces start-up popping noise to audio outputs
    - Top notch audio sensation delivers according to the audio configuration Separate layer for left and right track, ensuring both sound deliver equal quality
    Non-stop Challenger :
    - ASUS iCafe Labs Certified - Top games and 100+ peripherals tested
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger
    - PC Cleaner
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert
    ASUS EZ DIY :
    - ASUS EZ Flash 3
    - ASUS MyLogo 2
    - ASUS UEFI BIOS EZ Mode
    ASUS Q-Design :
    - ASUS Q-Slot
    - ASUS Q-DIMM
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit *2
  • Back I/O Ports
    1 x DVI-D
    1 x LAN (RJ45) port(s)
    4 x USB 3.0 (blue) Type-A
    4 x USB 2.0
    3 x Audio jack(s)
  • Internal I/O Ports
    1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
    1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
    1 x TPM header
    1 x COM port(s) connector(s)
    4 x SATA 6Gb/s connector(s)
    1 x Chassis Fan connector(s) (1 x 4 -pin)
    1 x System panel(s)
    1 x Clear CMOS jumper(s)
  • Accessories
    User's manual
    I/O Shield
    2 x SATA 6Gb/s cable(s)
    1 x Supporting DVD
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.7, WfM2.0, SM BIOS 2.7, ACPI 5.0, Multi-language BIOS,
    ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions, and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
    WfM 2.0, DMI 2.7, WOL by PME, PXE
  • Support Disc
    Drivers
    ASUS Utilities
    EZ Update
  • Form Factor
    mATX Form Factor
    8.9 inch x 7.6 inch ( 22.6 cm x 19.3 cm )
  • Note
    *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
    *2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
EX-B150M-V5-D3-ASUS-0406.BIN.zip
