is possible to disable internal RAM in this model?
can you please remove password Asus F512D
motherboard X512DK
Hi,
Can You repair bios bin please, AMD 7 X512DK Rev.2.1
Cheers
builds873.ziprepair bios X512DK Rev.2.1
please rebuild
Asus X512DK Plz remove password
send file bios i check beforeHi i have an issue with onboard ram on this board. I desoldered the ram from motherboard , then i tried to boot the laptop with an external ram stick , it boots up but when it loads in windows , it freeze . Can you help me disable the ram permanently from the board?
AMD mà clearme gìclearme giúp e
CPU KO CO XUNG CHẠY AAMD mà clearme gì
BIOS AMD nó không như Intel không có clearme, nếu nghi ngờ BIOS lỗi thì nạp file khácCPU KO CO XUNG CHẠY A
