SuperTecno
Good fellows, I have a laptop Asus Zenbook Flip UX363EAit does not turn on or charge the battery (actually if it comes to light a second, but the power light only gives a quick flash), had a short in this capacitor near the battery connector
There is a short also on this coil, the rest of the sources of the motherboard when the power button is pressed the voltage of the sources is turned on, but they fall off in 3 seconds.
The short is in the coil on the right, next to the four capacitors; lifting the R68 coil the short is on the top pad and the four capacitors on the right, the capacitors I have removed and checked one by one and they’re all fine.
I have injected one volt into the source and only have a consumption of 0.14 amps and with thermal camera no heating component is seen.
Where should I start to check to try to fix the failure of this laptop?
A greeting.
A greeting.
