You need check chipset.I have this laptop and none of the three USB are working, I tried to CMOS but there is no battery on this laptop, someone can help me, thanks
I thinh chepset is error you need Reballing or change new.The chipset is on the cpu? What should I look for?
Ports are not damaged and they have 5 volts, exept that when I plug in an usb device (cellphone, thumbdrive, etc) it doesn't detect anything. Tried with Windows and Linux and it's the same
You can check the management chip for USB 3.0, USB 3.0 can need setup add driver.Do you think so? Everything else works fine.
The issue started with the USB3 ports when I connected an USB carry, the carry never started and the USB went dead. The only thing that works is a USB cabled mouse (which is low amperage)
If all is well the only problem left is the chipset
You can try, but i think EC not manage USB.Yes it's all installed, I reinstalled Windows and tried with Ubuntu, still not working.
The chipset is ite it8995e-128 or what is that? thanks for your help
Yes, you need try it before where Reballing..So do you think that applying heat to the chipset would work?
Ok I just disassembled the notebook, here are the images:Yes, you need try it before where Reballing..
All in one, cpu and chipset.Ok I just disassembled the notebook, here are the images:
http://imgur.com/a/DBb3d
Can you point me where the chipset is so I can rebail it? thanks
I see motherboars this all is USB 3.0
You have replaced the USB 3.0 management chip ?
Need to check on the motherboard. I can do nothing more...Hi thanks for help
I did rebailing but it still doesn't work
Notebook has 2 usb 3.0 and 1 usb 2.0, none are working.
Can it be a blown fuse or something else? notebook is useless without usb
USB 3.0 is only working with USB 3.0 devices! usb 3.0 thumb drive, usb 3.0 carry, etc, usb 2.0 devices are not working, this may help
Yes I will send it to repair I think, thanksNeed to check on the motherboard. I can do nothing more...
