BIOS ASUS Q170M2
ASUS Q170M2
BIOS Q170M2-SI-1802
ASUS Q170M2 RG-Vinafix
  • CPU
    Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
    Supports Intel® 14 nm CPU
    * Refer to www.asus.com for CPU support list
  • Chipset
    Intel® Q170
  • Memory
    4 x DIMM, Max. 64GB, DDR4 2133 MHz Non-ECC, Un-buffered Memory
    * The maximum memory frequency supported varies by processor.
    * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
  • Graphic
    Multi-VGA output support : DVI-D/DVI-I/DisplayPort ports
    - Supports DVI-I with max. resolution 1920 x 1200 @ 60 Hz
    - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
    Supports up to 3 displays simultaneously
  • Multi-GPU Support
  • Expansion Slots
    1 x PCIe 3.0/2.0 x16 (x16 mode)
    1 x PCIe 3.0/2.0 x16 (x8 mode)
    1 x PCIe 3.0/2.0 x1
    1 x PCI
    1 x mini-PCIe (half-length)
  • Storage
    Intel® Q170 chipset :
    6 x SATA 6Gb/s port(s),
    1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)*
  • LAN
    Intel® I219LM, 1 x Gigabit LAN Controller(s)
    Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
    ASUS LAN Guard
  • Audio
    Realtek® ALC887 7.1-Channel High Definition Audio CODEC *1
    - Supports : Jack-detection, Front Panel Jack-retasking
  • USB Ports
    10 x USB 3.0/2.0 port(s) (6 at back panel, blue, 4 at mid-board)
    2 x USB 2.0/1.1 port(s) (2 at mid-board)
  • Special Features
    ASUS 5X Protection II :
    - ASUS DIGI+ VRM - 5 Phase digital power design
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger
    - Mobo Connect
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert 2+
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - ASUS UEFI BIOS EZ Mode
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Slot
    - ASUS Q-DIMM
    TPM IC Onboard
    Media Streamer
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit *2
  • Back I/O Ports
    1 x PS/2 keyboard (purple)
    1 x PS/2 mouse (green)
    1 x DVI-D
    1 x DVI-I
    1 x DisplayPort
    2 x LAN (RJ45) port(s)
    6 x USB 3.0 (blue)
    3 x Audio jack(s)
  • Internal I/O Ports
    1 x MONO out header *3
    2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
    1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
    1 x M.2 Socket 1 with E key, type 2230 Wi-Fi devices support
    1 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
    1 x LPT header
    2 x COM port(s) connector(s)
    6 x SATA 6Gb/s connector(s)
    1 x Internal speaker connector(s)
    1 x System panel(s)
    1 x Chassis Intrusion connector(s)
  • Accessories
    User's manual
    I/O Shield
    2 x SATA 6Gb/s cable(s)
    2 x M.2 Screw Package
    1 x Supporting DVD
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
    ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    ASUS EZ Update
  • Form Factor
    uATX Form Factor
    9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm )
  • Note
    *: M.2 shares SATA mode with SATA ports. Change this item before installing M.2 SATA devices.
    *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
    *2 Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
    *3: Use with amplified speaker is suggested.
Q170M2-SI-1802.BIN.zip
ASUS Q170M2 RG-Vinafix.pdf
