Ask ASUS FX517Z
Question & Answer Forums
ec no have builds
Good afternoon, I apologize for the mistake in sending the file.
This BIOS was previously rebuilt by you; however, it is currently not detecting the graphics card or the SSDs. I would like to know if it would be possible for you to check this issue.
Thank you in advance for your attention and availability.
DA0NJKMBAF0 REV F OLD.BIN
hi try
32MB_NEW.zip
Hello,
Thank you for the rebuild. I tried to reprogram the BIOS, and there has been some improvement.
Before the rebuild, the system was not recognizing either the RTX 3070 GPU or the NVMe drive. After the rebuild, both the GPU and the NVMe drive are now being recognized properly.
However, there is still an issue regarding the GPU memory, as the system is not recognizing the VRAM memories of the RTX 3070 correctly.
Additionally, I would also like to correct the serial number previously provided. The correct serial number is:
N9NRCX06C084380
Thank you for your attention and availability.
Hello,
N9NRCX06C084380
correct the serial number ISSU?
