Ask 6-71-NH5G0-D02
Question & Answer Forums
Hiroyuki Takeda
Active Member
VIP PRO
We have suffered from the following troubles: Help me!
・ I can't wake up from sleep
・ Charging itself can be done without any problem
・ When the power is turned on, the power supply is interrupted at an unspecified timing even though it is charging.
・ If you turn on the power after clearing the CMOS, it should start normally after restarting twice and then the third startup, but the power does not turn on the third time.
6-71-NH5G0-D02.BIN
cls.zip
