BIOS Micro-ATX industrial motherboard MX45Q2 R10 mATX LGA775 pn 08GSAQ45003203 MX45Q2
Micro-ATX industrial motherboard MX45Q2 R10 mATX LGA775 pn 08GSAQ45003203 MX45Q2.jpg
Specification (Item No: IM MX45Q2 , Ref ID: MX45Q2 ):
General Micro-ATX industrial motherboard with Socket 775, with dual G-LAN, VGA and RAID
form factor Micro-ATX
processor Socket 775 for Intel Core 2 Duo / Quad
FSB 800/1066/1333 MHz
Storage 4 x 240 pin socket for up to 8GB DDR3 SDRAM
ETC No
Cache L2 integrated in CPU
chipset Intel Q45 Express Chipset
BIOS Award PnP Flash BIOS
VGA connection Dual DVI (1 x DVI-D, 1 x DVI-I)
resolution max. 2048 x 1536 (32 Bit)
chipset Intel Graphics Media Accelerator 4500
RAM 1 MB (DVMT used, up to 384MB)
DVI Is supported
Super I / O Parallel 1 x SPP/EPP/ECP
Serial 2 x RS-232C (16550 UART compatible), Pin 9 each selectable for 5V or 12V.
Digital I / O 16 bit Digital I / O port, programmable via software. TTL signal.
USB 12 x USB-Ports. USB v2.0 Standard (4 x extern, 8 x intern)
Trusted Platform Modul (TPM) Intel TPM integrated
Active-Management-Technologie (AMT) Yes, AMT v5.0
Intelligent fan control Yes (three-stage)
Gigabit Ethernet 1 x Intel 82567LM PCI Express G-LAN und 1 x Intel 82574L PCI Express G-LAN on Board
Enhanced-IDE JMicron JMB368 PCI Express to PATA Controller for 2 x Dual Ultra DMA100 IDE devices.
RAID S-ATA Raid 0/1/0+1/5 on board.
Serial-ATA 6 x Serial ATA on board
Sound Realtek ALC888 High Definition Audio with S / PDIF output
Watchdog Yes, via software (1 - 255 seconds)
hardware monitoring And
power supply 24 pin connector and ATX 4 Pin + 12V connector for CPU
Slots PCI 1 piece
PCI Express x1 1 piece
PCI Express x16 1 piece
PCI Express x4 1 piece
Relative humidity 0-90% non-condensing
operating temperatur 0°C ~ 50°C
dimensions 244 x 244mm
RoHS compliant And
  • Article Article
Replies
Views
1K
  • Article Article
BIOS HI05
Replies
Views
2K
  • Article Article
Replies
Views
1K
  • Article Article
Replies
Views
2K
