Good evening. Please help fix the BIOS data for the Acer AN515-55 model. The data allows the device to power on, but there is no display.
post backup and snidEste es el archivo del que te hablaba.
Technical download for SOIC8ORIGEN. Resource type: BIOS / firmware dump. Flash chip: XM25QH128A · SPI NOR flash · XMC (16 MB). The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
d94bdf2ecfbe96dacb457160af1dd04567233206e67e3cb88f1cbbc169d59e7aXM25QH128A@SOIC8ORIGENThis is the file to be repaired.
Technical download for Acer Nitro AN515. Resource type: BIOS / firmware dump, BIOS Builds. BIOS build and DMI restoration service: device identity data and firmware regions should be checked before programming. Flash chip: XM25QH128A · SPI NOR flash · XMC (16 MB). Verify the exact model and board revision before programming or repair work.
5c4455116f04e8cded9680739c0ce854e5073fe3bd7ac93d14b11192a7793479
