Alienware X14 hds41 la-L381p
Alienware X14 hds41 la-L381p 20231219_162721_SVOD3 original la-l381p.bin.zip9.7 MB · Views: 244
Technical download for SVOD4. Resource type: BIOS / firmware dump. SPI flash capacity: 32 MB. The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
bed201dd89281c27a9c12e11b8334d0a4c5f80648e11f9180b388668c993248f20260802_135110_SVOD4.binAlienware X14 hds41 la-L381p
no display
service tag : 5TMRTQ3
Technical download for Dell Alienware X14. Resource type: BIOS / firmware dump, BIOS Builds. BIOS build and DMI restoration service: device identity data and firmware regions should be checked before programming. Motherboard code: LA-L381P. SPI flash capacity: 32 MB. The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
9c7346bd0c3ef57af7f1f8283f8914e28652e22b1ef0fd4dfa5083883997273bAlienware X14 hds41 la-L381p 20260802_135110_SVOD4_Builds.bin
