AMD ko builds hay sửa gì hết bạn nghĩ ngờ thì cứ BIOS khác mà nạp thôi nó ko kén hay lỗi vặt như IntelFILE NÀY CÓ NGUỒN KHÔNG HÌNH THỨC , NHỜ AD BUILD GIÚP EM ,
SERIAL CON NÀY :
82L005BVN
ko tìm thấy file nào để nạp , ad có file này cho mình xin nhaAMD ko builds hay sửa gì hết bạn nghĩ ngờ thì cứ BIOS khác mà nạp thôi nó ko kén hay lỗi vặt như Intel
NM-D901 REV:1.0
NO DISPLAY
AMD.zipplease repair my bios no display , thanks
IS THE FILE YOU GIVEN THE SAME AS THE PREVIOUS POST? I HAVE TRIED THAT BUT STILL BLANK NO DISPLAY
I think you need check AMD chipsetIS THE FILE YOU GIVEN THE SAME AS THE PREVIOUS POST? I HAVE TRIED THAT BUT STILL BLANK NO DISPLAY
FIX PLEASE DURING UPDATE LAPTOP TURN OFF
8mb same model ?Adakah file ic 8MB nya?
16mb dump corrupted8mb same model ?
send file old i check
If you're not sure, you need to try another bios to compare. I can't check if it's the original bios of that device.16mb dump corrupted
8mb dump dont know if corrupted or not
already used some bin.
already tried all of above bios no switch, but with original bios can switch. this is ori bios. but corruptedIf you're not sure, you need to try another bios to compare. I can't check if it's the original bios of that device.
AMD 1 bios is right why above have more file 8mb ??already tried all of above bios no switch, but with original bios can switch. this is ori bios. but corrupted
