Need schematic or Board view for Asus X1404ZA R3.0 Main Board
thanks
thanks
16mb biosASUS X1504ZA POWER ON NO DISPLAY
CUSTOMER BIOS BLANK DISPLAY
MOTHERBOARD PART NUMBER
X1404ZA R3.0
THIS BIOS 32MB
CUSTOMER BIOS 16MB
16MB BIOS ONLY NEED SIR
Technical download for SVOD4. Resource type: BIOS / firmware dump. SPI flash capacity: 32 MB. Verify the exact model and board revision before programming or repair work.
fd368385dae288144226ed14d3f158b5608ae7e5ac9917563b244b4d75efb58bSN S2N0CV02E14506Basus x1404za r3.0
Rebuild; there is no image
SHA-256 bfa8dc13bd51770958e9423d85608d3166b911f494c1ae5f42fb95d12abb1ddb
FIXX.romREQ:BUILDSN S2N0CV02E14506B
Technical download for X1404ZA. Resource type: BIOS / firmware dump. SPI flash capacity: 32 MB. The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
517f1fe4d66b6d73734e98b4ebea196d02aab46603d4bf4701996a0e2f1f61c3X1404ZA R3.0 32MB.BINSHA-256 3a079be89e3116e5ea0f6af365404ce217e3b7526e3df32f2ff81b58edc3e673
REQ:BUILD
Technical download for X1404ZA. Resource type: BIOS / firmware dump, BIOS Builds. BIOS build and DMI restoration service: device identity data and firmware regions should be checked before programming. SPI flash capacity: 32 MB. The archive contains 1 entries. Verify the exact model and board revision before programming or repair work.
46f94f6afdb57390f05a0d93ef78916bd1fa4cb3ba96e800eb2e1ef906d2c500X1404ZA R3.0 32MB_Builds.bincould you please check you didnt sent me the build bin file you just sent the build report.
SHA-256 f3a1a5c85ca2609d7ae3dacb902b11b4e5f1fe9b2eab0c111362fe288fe8f176
stuck on logo_dmi_Builds.binTry the file at the top of the post.Sorry, it did not work; it only turned on once and then shut off.
