Hello can you fix my dump HP Pavilion x360 14-dw1134nr LAIKA-6050a3202801-MB-A03(A3) . No display
PLZ HELP MEhi sir this bios hardrive not connected to system plz help me
SSD nvme ?hi sir this bios hardrive not connected to system plz help me
not connected ssd nvmeSSD nvme ?
nvme only works with Original biosnot connected ssd nvme
No Display plz help
bbb.zipModel: HP Pavilion x360 14-dw1134nr
Board code: LAIKA-6050a3202801-MB-A03(A3)
Issue: Black screen only
Please repair bios bin thank you.
THANK YOU!!!
Hi, can you fix this BIOS? No display, mb ok....
try more bios on top and compareIt didn't work... I've tried to run the HP BIOS RECOVERY, and I got a notification that the BIOS is corrupted on the screen.. witch means that it's only a fault BIOS... can you please double check ? Thanks again for the help !
If the bios has the same problem then follow the on-screen instructionsAlready tried all the previous BIOS, same issue.
This is the RECOVERY SCREEN:
Actually, the error in the photo is not a problem that can be fixed directly from the bios fileI've tried all the steps for the recovery, different versions but nothing worked... The device won't accept the recovery file... Can you please help me to fix the original one ?
