dell 5300 18827-1 bios lock send me clear me sir
but file bios you send error data, can not patchsend me patch file
i have another laptop bios lock u can check with serial number..... if possible
clean the BIOS chip and reprogram this biosi have another laptop bios lock u can check with serial number..... if possible
i try this bios but notworking single orange light is blink but no power on . but i used oldmaster bios ic its working . display working bios lock showingclean the BIOS chip and reprogram this bios
dell 5300 bios lock.BIN
and make one video show display lock I check
it's the bios you providedi try this bios but notworking single orange light is blink but no power on . but i used oldmaster bios ic its working . display working bios lock showing
sorry sir we have send another bios lock file please kindly clear the bios file .if it is possible means i will send bios file
all the bios you sent above have the same problem, i think you need to check the programming tool first or you will kill all of these laptops
please reply this file cheak after sirsir i will change bios programing tool now this bios file is ok now u can check and update sir please
Late display. Please fix. Thank you
Build giúp e file này ạ
