Vostro 3525 LA-L945P BIOS
Inspiron 3525 1.12.0 AMD.bin.zip
EC this use 160KBHi, I was able to read it, it's kb9542q. Do you have a new file? This one is corrupted due to a failed update. If you have another file or if this one can be repaired, I would appreciate it.
no TIENE WIFI Y NO AY USB LO PUEDES SOLUCIONAR
not for model on top ?no TIENE WIFI Y NO AY USB LO PUEDES SOLUCIONAR
password in EC you can Programming it or buy master enterLA-945P CON CONTRASEÑA
send photo display lock I check beforedoomprar enviame el enlace y el precio
send I file oldI need BIN EC kb9542qf2
DELL 3525 hdl5d la l945p rev 1.0 a00
send I file old
I programmed it and the power light blinked continuously, the device did not turn on and the battery did not charge. Do you have another BIN to try? DELL 3525 AMD
I think problem AMD chipsetI programmed it and the power light blinked continuously, the device did not turn on and the battery did not charge. Do you have another BIN to try? DELL 3525 AMD
No, con otro KBC el dispositivo funciona normalmente, pero el PS_ID está en cortocircuito debido a una fuga de 19V, y como el dispositivo no reconoce el cargador, funciona a una frecuencia de CPU limitada y no carga la batería.Creo que el problema está en el chipset AMD.
Hola, ¿pudiste encontrar algún binario que funcione para EC? Tengo el mismo problema.Hola, pude leerlo, es kb9542q. ¿Tienes un archivo nuevo? Este está dañado debido a una actualización fallida. Si tienes otro archivo o si este se puede reparar, te lo agradecería.
We found the problem: the KB9542QF2 is 160K (not 128K) . By reading the old one and reprogramming the device, it now charges the battery and turns on. I'm leaving this file as a contribution for those looking for DELL 3525 EC binaries.I think problem AMD chipset
