DELL VOSTRO 3500
LA-K032P
ST:7FT43G3
Servis etiketi kaydedilmiyor, sürekli hata veriyor ve fanlar son hızda çalışıyor. Lütfen yardımcı olabilir misiniz? BIOS dosyalarından birini yedeklemeyi başardım, ancak diğerini alamadım.
pach file its paidHello, my device works with the BIOS you sent, but I keep getting the manufacturing mode active error message every time I turn on the computer. When I press ALT+F, the fans return to normal, but only until the computer is turned off. When it is turned back on, the same problem occurs
Fiyatı ne kadaryama dosyası ücretlidir
error this patch 35$Hello, my device works with the BIOS you sent, but I keep getting the manufacturing mode active error message every time I turn on the computer. When I press ALT+F, the fans return to normal, but only until the computer is turned off. When it is turned back on, the same problem occurs
