llenoalfie
Registered member
hi sir can you help me needed bin file for this chip asus g512li
thanks in advance
thanks in advance
why need Programming it ?hi sir can you help me needed bin file for this chip asus g512li
thanks in advance
ITS gpu bios not a main bioshi sir can you help me needed bin file for this chip asus g512li
thanks in advance
bin file already deleted/corrupted this chip is empty do you have bin file sir for this one thanks so muchwhy need Programming it ?
send file old i check
issue?this is previous file can u check this sir is this correct for that chip thanks in advance
no display when u press power coming on but not spinning the fanissue?
a bit heat from gpu but cpu not no heat indication upon checking no voltage coming from cpuno display when u press power coming on but not spinning the fan
