전원이 잠깐 들어왔다가 꺼집니다. 수정해주세요
제공하신 파일은 전원이 안들어옵니다.
unpassDAZGRMB2AC0 rev:
bios paasword problem .
please unlock
Admin
Adminunpass
Admin
no dispay problem this bios .please check again & password remove from my original bios
hi ser ples unpassword
Predator Helios Neo 16
dazgrmb2ac0 REV C
Do you have the ITE programming? It's the it5570e-256 CXA????
thx
Can you repair? Wifi stay with yellow sign "device cannot start (code 10)".
post snidPlease ClearME
Please ClearME
bios you send not right modelPlease ClearME
it is Original bios ? GPU I can not check from biosplease fix the bios, gpu not detecting on windows but showing on bios 0 temperature .
yes original , you can fix issueit is Original bios ? GPU I can not check from bios
