Flex 5-14ALC05 - gjcn25ww .BIN
Flex 5-14ALC05 - gjcn25ww .BIN.zip
AMD no have builds you can Programming any bios otherno display, repair pls.
AMD need. Programming one bios newPlease fix me
AMD Programming bios hereflex 5 as above please check bios asap
thank you
AMD Please try one bios new and check AMD chipsetpls rebuild with other bios works but dont work m.2
flex 5 14alc05
AMDFlex 5 14ALC05 - please , can you repair this BIOS ? No image with this.
Tried this one . It boots but I need the original serial number in it . Can you repair the original file?
There is no other way. If you want to get s/n Original, you need to buy a $25 patchTried this one . It boots but I need the original serial number in it . Can you repair the original file?
AMD need Programming bios on topHola podrias reparar esta bios. gracias
post snidgracias
