Model: Elitebook 645 G10
Motherboard model: DA0X9TMB8D1 REV: D
hi sir system is no disply plz rebuild.thanks
Motherboard code ?hi sir system is no disply plz rebuild.thanks
da0x9smb8d1 rev.DMotherboard code ?
da0x9smb8d1 rev.D
cls and builds not fix error thisPlease Clear This Eror Thanks
how can solve this problemcls and builds not fix error this
Where does the cause come from?how can solve this problem
Does it lock after connecting to wifi or shutting down?Hello, please, I need help repairing this BIOS.
The symptom is that with the WiFi card connected, the laptop powers on and shuts down again after around 5 seconds. We already tested with a different WiFi card and the problem persists, so at first we thought it was a physical motherboard issue.
However, after flashing a clean BIOS and EC BIN file, the laptop powers on correctly even with the WiFi card installed. Because of this, we are quite sure the issue is BIOS-related.
Could you please help us repair the original BIOS file?
Thank you very much.
If power on with card installed, power on 5 seconds and off, no displayDoes it lock after connecting to wifi or shutting down?
If so, the hardware has a problemIf power on with card installed, power on 5 seconds and off, no display
If put card when its power on, in hot, total hang, need power off with power button 10 sec.
BR
With clean dump boot with wifi attachedIf so, the hardware has a problem
clearme ?With clean dump boot with wifi attached
clearme ?
sorry., clean no, another dump downloaded in post 1clearme ?
now you need i help what ?sorry., clean no, another dump downloaded in post 1
Repair original bios if it possiblenow you need i help what ?
isuu?Repair original bios if it possible
no boot with wiffi attachedisuu?
