Victus by HP 15.6 inch Gaming Laptop 15-fb1000 DAG3PRMB8D0
08C30
08C30
08C30.bin.zip
after write your bios power not come,
try more bios on topafter write your bios power not come,
any help advice,
If AMD then there is nothing to check the BIOS you can use any other bios of the same modelYou can repair it; it has an update error, and to rule out a Hypervisor Error 0x2000, it's an AMD system. I'm sharing the original BIOS from the website so you can compare it.
THE ORIGINAL BIOS FROM HP IS 08C30, THE ORIGINAL OF THE LAPTOP IS THE SVOD DATA
แอคมินไม่มีภาพซ่อมให้ฉันด้วย
PLZ UNPASS
HP 15 FA006LA NO POWER REPAIR BIOS ORIGINAL 56679
fix em lỗi mở máy bắt update, bị mất camera ạ
please check, no power
hi tryPlease Fix bios corrupted .
Don't give me the file from post #1 its no use .
Please fix my file please .
Model: 15-fb1041AX
SN : 5CD421DNLJ
