BIOS GM5ZGXW
I have an issue with the display
The internal display does not get detected. And I’m unable to enter the BIOS.
The external display works after a longer startup time.
I think the PC is doing a BIOS restart after every startup.
Also, if I change the settings to iGPU, there is no display anymore.
You need to determine where the problem is so you can fix it
