Ask DAZ8IAMBACO Rev C
vanescar
Active Member
VIP PRO
Hi everyone,
I’m having an issue with my Acer laptop (TravelMate P214-53 series, motherboard model DAZ8IAMBACO Rev C).
When I press the power button, the laptop powers on — lights and fans start — but after a few seconds it stops and doesn’t POST. There is no display and no beeps.
I suspect the BIOS might be corrupted, so I would like to test this by flashing a known-good or compatible BIOS file for this exact motherboard revision.
If anyone has:
a working BIOS dump for DAZ8IAMBACO Rev C
information about BIOS compatibility for this board
or guidance on how to recover/flash the BIOS (programmer, jumper points, etc.)
…I would really appreciate your help.
Thanks in advance!
[email protected]
Hi everyone,
If anyone has:
Thanks in advance!
1bb.zip
I previously received a BIOS ROM from the technician thienbui, but it was not working. After flashing it, the situation got worse: the keyboard backlight and the fans no longer powered on.
I then reprogrammed my previous BIOS backup, and the laptop returned to the same condition as before.
so can laptop not error bios
The file you gave me was supposed to be a working BIOS and make the notebook function like it did before. Instead, with that file the fans and the backlight no longer turned on. I would like to understand if you can explain what happened.
