Lenovo ThinkPad X1 Carbon 9th-Gen (Type 20XW, 20XX) NM-D341
Lenovo X1 Carbon Gen.9 HYG60 HX4B0 NM-D341 photo
Lenovo ThinkPad X1 Yoga Gen 6 - NM-D341 Ver 3.13.pdf
Schematics, boardview
Lenovo ThinkPad X1 Yoga Gen 6 - NM-D341 REV1.0 BoardView PDF.pdf
BiosDump U49.bin
BiosDump U801.bin
This model cannot currently be unlocked from BIOS
it is not locked!
the problem was at the middle of bios update, the laptop shut down, and bios got corrupted
now with your dump, or from Lenovo website it gives this error & can't enter bios or boot an devices just boot loop forever
how to fix error 0183 and 2205 ?
Hi. We are laptop repair service. As Client said, he has a problem after win updating. After laptop reboot, he received black screen, but works perferct with external monitor. Also laptop do not start with the battery, only with external power, but works perfect without ext power after starting. Also laptop do not work with the keyboard and toch. Can Y repair the BIOS ?
BiosDump U49.bin
BiosDump U801.bin
If you are a technician, you must know how to test, you can't just listen to the customer
The first thing you need to do is try the new BIOS to see what the results are?
Yes, we flash new BIOS from and this topic (from krlos). Laptop also works only with external LCD. For the 1st start laptop try Reading ME firmware..., and after reboot write Failed to recover ME firmware. Then write Check Date and time and after reboot again Read Me firmware/
But with Your BIOS from begining of the topic on fhe 1st start laptop Reading ME firmware. Laptop also can start with the battery!!! after reset with ext power Laptop Flash the BIOS , then write Check Date and time and after reboot again Flash the BIOS
