Unlock Use SCBO unlock Apple T2 chip
EFI iCloud Firmware SCBO
1: Get HASH CODE
Press and hold when you see the lock screen:
Next:
Press Simultaneously:
2: Instructions for creating SCBO bootable USB
cp ~/Desktop/SCBO.bin /Volumes/Firmware/.SCBO
cp ~/Desktop/SCBO.bin /Volumes/Firmware/._SCBO
Next:
  1. Turn off computer locked.​
  2. Insert the Flash drive into the computer.​
  3. Turn on the computer while pressing and holding the Option key.​
  4. You should see the lock symbol for a moment, and then the computer should restart to the Startup Manager.​
  5. If you still see digit "passcode" lock after these steps at startup, reset the NVRAM by holding down Command-Option-P-R while restarting the computer.​
After EFI is removed use your own Bootable OS X and install it. First installation don't do over WiFi.
You need to have USB and other apple computer available to create USB
This is just an article that introduces the steps to follow, in order to successfully unlock you need to pay more. :p
SCBO-signed1.bin
SCBO-signed2.bin
SCBO-signed3.bin
Please where can I download Apple Configurator 2 application? my MacBook Pro does not have Apple Configurator 2, as MacBook Pro 2018. Can someone please help by sending me the version 2 please?
You can download from Apple store.If icloud activation lock dont restore via Apple configurator2.
Currently 7.2 or previous all ibridge support bypass.If you restore will ibridge 7.4 will not support bypass.
Waiting @admin he will give you tool you will check ibridge version in Dfu mode open tool and conform.
Oh thank you. I will appreciate if I can have a tool checker please.
Regarding Apple Config, there is no Apple configuration 2 in Apple Store. Where else can I get it? I noticed if I use the current Apple configuration, it stops a lot a the middle and it terminates. What could go wrong please?
In bypass tool you can check only ibridge version.
I dont know which Mac os you use.But search in google you need must use Mac os find in App store have Apc2.
