GU603ZX.cad boardview
GU603ZX-F1 BIOS
GU603ZX-F1 BIOS
GU603ZX.cad.zip
GU603ZX-F1.308.bin.zip
send file old i checkI need the bin for this Nvidia U7802 card @ThienBui
Hello, I am getting a post loop no display would it be possible to build a new bios? Board is GA603ZX and here is the bios dump and new downloaded bios update from ASUS.. Any help would be very much appreciated.. Thankssend file old i check
try more BIOS new and check hardwareI tried the bios you sent and I am getting no lights at all completely dead.. Any idea's?
I have lights and power on with the bios I sent you.. I tried old bios again and same thing it powers up battery charges but reboots over and over.. Yor bios no power at all for some reason..try more BIOS new and check hardware
If you could double check the bios that would be great. I dont have 3.3 or 5v rails with your bios but with mine i do but boot loops..I have lights and power on with the bios I sent you.. I tried old bios again and same thing it powers up battery charges but reboots over and over.. Yor bios no power at all for some reason..
The problem you mentioned cannot be checked from the biosIf you could double check the bios that would be great. I dont have 3.3 or 5v rails with your bios but with mine i do but boot loops..
There was a misunderstanding..
What I'm trying to say is with the bios you sent to me the motherboard has no voltages present at all but with the original BIOS it has all the voltages present so the bios you sent obviously doesn't work or it would at least have the power rails present. Any help would be appreciated.. ThanksThe bios communicates with the power management IC aka EC chip super io and chipset all 3 must be present and working somewhat correctly before the power rails will become available..
I can't use the new bios from Asus because it's 19mb too big and not designed to be flashed with a programmer.. Can you convert it to SPI bios 16mb?so try adding new BIOS not always builds will work and it may not have the same result as original BIOS
No, that's just the bios for updating, not for programmingI can't use the new bios from Asus because it's 19mb too big and not designed to be flashed with a programmer.. Can you convert it to SPI bios 16mb?
Yeah I know.. Any idea why it has power and lights with the original bios but has no power with the bios from you?No, that's just the bios for updating, not for programming
late display ?Hi, can you clear bios on top.
It`s work, but display apears in 20s
