Hello thank you very much, you have various problems, the function does not work AUTOPROFILE, hangs a continuation, user profiles already pre-installed on them, but I have the problem that the cards I deventano dark side bottom, someone has the right procedure to build ad hoc profiles with this rework? you also have some more info to use machines to three areas like mine? how can I change the rate,
thanks
