Jovy® PC Suite Interface Features:
Interactive and Easy to use Interface.
Multi-languages interface.
Fast USB 2.0 connection.
Profiles:
- Profiles Creation: where the user can create standard profiles or free
mode profiles then download it to RE-8500 memory or save it on PC.
- Profiles Editing: user can load any saved profile on PC and edit its
parameters.
- Profile manager mode: where the user will be able to import, edit,
delete and save the profiles saved on RE-8500 memory could be redownload
it to RE-8500.
Processes:
- Run manual processes or saved Profile process from the machine
directly or through PC suite.
- Monitoring heat distribution on PCB by drawing thermo-couples
readings graph.
- Analyze the heat distribution on PCB by monitoring thermo-couples
reading on different five positions in a real time.
- Do analysis on running process thermo-couples reading in real time.
- Save unlimited number of running processes graphs and data (thermocouples
reading) files.
Upgrade RE-8500 firmware through Jovy® PC Suite through USB 2.0
connection.
Full Control of all RE-8500 peripherals like fan, pump and laser.
Support Celsius and Fahrenheit temperature unit standards.
Offline mode: Can create profiles and analyse process data files without
connecting to RE-8500.
RE8500_manual.pdf
