MS-91A4 THIDWICK IU POWEREDGE R610
Discussion in 'Server' started by ThienBui, Nov 5, 2014.
  1. ThienBui
    Staff Member
    Dec 13, 2013
    42,105
    3,235
    Main Server
    dellpowerR620-2.
    * Dell PowerEdge R610 Server
    * 1 x Intel® Xeon Quad Core E5640 2.66Ghz 12MB L3 5.86GT/s Turbo, HT (Support Intel® Xeon® 5500 and 5600 Sequence - 8 Processor Cores)
    * 2 x 2GB Dual Rank ECC RDIMMs 1333Mhz memory (Up to 192GB)
    * 1 x 500GB Hot-Plug SATA 3Gbps 7200rpm 2.5" (Max 6HDDs)
    * Power supply 502Watts Non-Redundant
    Processors
    Intel® Xeon® processor 5500 and 5600 series
    Six-Core Intel® Xeon®
    Quad-Core Intel® Xeon®
    Chipset
    IntelTM 5520 (Tylersberg)
    Memory
    Up to 192GB3 (12 DIMM slots/6 per-processor): 1GB/2GB/4GB/8GB/16GB DDR3 800MHz, 1066MHz or 1333MHz
    Embedded Hypervisor (Optional)
    Citrix® XenServer®
    Microsoft® Windows Server® 2008, with Hyper-VTM
    VMware® ESXiv 3.5
    Operating Systems
    Microsoft® Windows® Small Business Server 2008
    Microsoft® Windows® Essential Business Server 2008
    Microsoft Windows® Server 2008 SP2, x86/x64 (x64 includes Hyper-VTM )
    Microsoft Windows® Server 2008 R2, x64 (includes Hyper-VTM v2)Microsoft® Windows® HPC Server 2008
    Novell® SUSE® Linux Enterprise Server
    Red Hat® Enterprise Linux
    Sun® SolarisTM
    Storage
    SAS, Near-line SAS, SSD and SATA:
    PERC H200 (6Gb/s)
    PERC H700 (6Gb/s) with 512MB Non-Volatile cache
    PERC H700 (6Gb/s) with 512MB battery-backed cache
    SAS 6/iR
    PERC 6/i with 256MB battery-backed cache
    External:
    PERC H800 (6Gb/s) with 512MB Non-Volatile cache
    PERC H800 (6Gb/s) with 512MB of battery-backed cache
    PERC 6/E with 256MB or 512MB of battery-backed cache
    External HBAs (non-RAID):
    6Gbps SAS HBA
    SAS 5/E HBA
    LSI2032 PCIe SCSI HBA
    Communications
    Optional add-in NICs:
    Dual Port 10GB Enhanced Intel Ethernet Server Adapter X520-DA2 (FcoE Ready for Future Enablement)
    Intel PRO/1000 PT Dual Port Server Adapter, Gigabit, Copper, PCI-E x4
    Intel PRO/1000 VT Quad Port Server Adapter, Gigabit, Copper, PCI-E x4
    Intel 10GBase-T Copper Single Port NIC, PCI-E x8
    Intel Single Port Server Adapter, 10Gigabit, SR Optical, PCI-E x8
    Broadcom® BMC57710 10Base-T Cooper Single Port NIC, PCI-E x8
    Broadcom® BMC5709C IPV6 Gigabit Copper Dual Port NIC with TOE and iSCSI Offload, PCI-E x4
    Broadcom® BMC5709C IPV6 Gigabit Copper Dual Port NIC with TOE, PCI-E x4
    Broadcom® NetXtreme® II 57711 Dual Port Direct Attach 10Gb Ethernet PCI-Express Network Interface Card with TOE and iSCSI Offload
    Intel® Gigabit ET Dual Port Server Adapter
    Intel® Gigabit ET Quad Port Server Adapter
    Broadcom 10GbE NIC, Broadcom Dual Port 10GbE SFP+
    Optional add in HBAs:
    Qlogic® QLE 2462 FC4 Dual Port 4 Gbps Fiber Channel HBA
    Qlogic® QLE 220 FC4 Single Port 4 Gbps Fiber Channel HBA
    Qlogic® QLE 2460 FC4 Single Port 4 Gbps Fiber Channel HBA
    Qlogic® QLE2562 FC8 Dual-channel HBA, PCI-E Gen 2 x4
    Qlogic® QLE2560 FC8 Single-channel HBA, PCI-E Gen 2 x4
    Emulex® LPe-1150 FC4 Single Port 4 Gbps Fiber Channel HBA, PCI-E x4
    Emulex® LPe-11002 FC4 Dual Port 4 Gbps Fiber Channel HBA, PCI-E x4
    Emulex® LPe-12000, FC8 Single Port 4 Gbps Fiber Channel HBA, PCI-E Gen 2 x4
    Emulex® LPe-12002, FC8 Dual Port 4 Gbps Fiber Channel HBA, PCI-E Gen 2 x4
    Power Supplies
    Two hot plug high efficient 502w PSU (Energy Smart) or
    Two hot-plug 717W PSUs (High Output)
    Uninterruptible Power supplies
    1000W-5600W
    2700W-5600W High Efficiency Online
    Extended Battery Module (EBM)
    Network Management Card
    Availability
    Hot-plug hard drives, hot-plug redundant power, redundant cooling, ECC memory, Single Device Data Correction (SDDC), supports memory demand, patrol scrubbing and high availability failover cluster
    Graphics
    Integrated Matrox G200, 8 MB shared video memory
    Chassis
    R610 Rack
    Height: 4.26cm (1.68”)
    Width: 48.24cm (18.99”) (includes rack latches)
    Depth: 77.2cm (30.39”) (includes PSU handles and bezel)
    Weight (maximum config): 17.69Kgs (39lbs)
    Management
    Dell OpenManage featuring Dell Management Console
    Lifecycle Controller
    iDRAC6 Enterprise (Optional)
    VFlash (Optional)
    Fans
    Standard redundant cooling
    Acoustics
    Typically configured6 2.5” chassis in 23 ± 2 C ambient
    Idle: LwA-UL7 = 5.3 bels, LpAm8 = 35 dBA
    Rack Support
    ReadyRailsTM sliding rails for 4-post Racks:
    Support tool-less installation in 19” EIA-310-E compliant square or unthreaded round hole 4-post racks including all Dell 42xx & 24xx racks
    NOTE: Threaded 4-post racks require the static ReadyRailsTM kit or 3rd party conversion kits available through Dell Software & Peripherals
    Support full extension of the system out of the rack to allow serviceability of key internal components
    Support optional cable management arm (CMA) except on Dell 4200 & 2400 racks and 3rd party racks that are less than 1m in depth
    Rail depth without the CMA: 798 mm (with outer CMA brackets attached), 768 mm (with outer CMA brackets removed)
    Rail depth with the CMA: 887 mm
    Square-hole rack adjustment range: 692-756 mm
    Round-hole rack adjustment range: 678-749 mm
    ReadyRailsTM static rails for 4-post & 2-post Racks:
    Support tooled installation in 19” EIA-310-E compliant threaded hole 4-post and 2-post racks
    Rail depth: 608 mm
    Square-hole rack adjustment range: 588-828 mm
    Round-hole rack adjustment range: 574-821 mm
    Threaded-hole rack adjustment range: 592-846 mm
    Regulatory and Environmental Compliance
    Regulatory Model: E01S
    Regulatory Type: E01S001
    #1 ThienBui, Nov 5, 2014
    Similar Threads - 91A4 THIDWICK POWEREDGE Forum Date
    MS-95R5 MX848 G138M 11G THIDWICK SAS BACKPLANE DELL R610 Server Nov 7, 2014
