DESCRIPTION
The PCA24S08 provides 8192 bits of serial electrically erasable and programmable Read-only memory (EEPROM) organized as 1024 words of 8 bits each. Data bytes are received and transmitted via the serial I2C-bus. Access permissions limiting reads or writes are set via the I2C-bus to isolate blocks of memory from improper access. The PCA24S08 is intended to be pin compatible with standard 24C08 serial EEPROM devices except for pins 1, 2, and 3, which are address pins in the standard part. Other exceptions to the
PCA24C08 serial EEPROM datasheet are noted the “Serial EEPROM Exception” section later in this document.
All bits are sent to or read from the device, most significant bit first, in a manner consistent with the 24C08 serial EEPROM. The bit fields in this document are correspondingly listed with the MSB on
the left and the LSB on the right. The EEPROM memory is broken up into 8 blocks of 1 k bits (128 bytes) each. Within each block, the memory is physically organized in to 8 pages of 128 bits (16 bytes) each. In addition to these 8 k bits, there are two more 128-bit pages that are used to store the access protection and ID information. There are a total of 8448 bits of EEPROM memory available in the PCA24S08.
Access protection (both read and write) is organized on a block basis for blocks 1 through 7 and on a page and a block basis for block 0. Protection information for these blocks and pages is stored
in one of the additional pages of EEPROM memory that is addressed separately from the main data storage array. See “Access Protection” for more details.
The ID value (see “ID Configuration”) is located in the ID page of the EEPROM, the second of the additional 16 byte pages. Writes from the serial interface may include from one to 16 bytes at a time, depending on the protocol followed by the bus master. All page accesses must be properly aligned to the internal EEPROM page.
The EEPROM memory offers an endurance of 100,000 write cycles per byte, with 10 year data retention. Writes to the EEPROM take less than 5 ms to complete. After manufacturing, all EEPROM bits will be set to a value of ‘1’.
FEATURES
• Non-volatile storage of 8 kbits organized as 8 blocks of 128 bytes each
• I2C interface logic
• Compatible with 24C08 Serial EEPROM, and alternate source of Atmel AT24RF08C without the RF interface
• Write operation:
– Byte write mode
– 16-byte page write mode
• Read operation:
– Sequential read
– Random read
• Programmable access protection to limit reads and writes
• Lock/unlock function
• Write protect feature protecting the full memory array against write operations
• Self timed write cycle
• Internal power-on reset
• High reliability:
– Ten years non-volatile data retention time
– 100,000 write cycle endurance
• Low power CMOS technology
• Operating power supply voltage range of 2.5 V to 3.6 V
• 0 to 400 kHz clock frequency
• ESD protection exceeds 2000 V HBM per JESD22-A114, 200 V MM per JESD22-A115 and 1000 V CDM per JESD22-C101
• Latch-up testing is done to JEDEC Standard JESD78 which exceeds 100 mA
• Packages offered: SO8, TSSOP8
WRITE OPERATIONS
Write operations on the device can be performed only when WP is held LOW. When WP pin is held HIGH, content of the full memory is protected (Block 0 to Block 7, APP Registers, ID Page), and no write
operation is allowed.
Byte/word write: Write command may be used to set the address for a subsequent Read command. For a write operation, the PCA24S08 requires a second address field. The address field associated with the two software selectable bits in the slave address is a word address providing access to the 1024 bytes of memory, as shown in Figure 4. Upon receipt of the word address, the PCA24S08 responds with an acknowledge and awaits the next eight bits of data, again responding with an acknowledge. Word
address is automatically incremented. Figure 5 shows how the memory array is addressed when the slave address byte and address field byte are sent. The master terminates the transfer by generating a STOP condition. After this STOP condition, the Erase/Write (E/W) cycle starts and the I2C-bus is free for another
transmission. Up to 16 bytes of data can be written in the slave writing sequence (E/W cycle).
Synchronous Step-Down Converter RT8015D
FEATURES
• Write operation:
– Byte write mode
• Read operation:
– Sequential read
– Random read
• High reliability:
WRITE OPERATIONS
