Hi.
I have a Asus X552MJ Laptop on my shop,
https://vinafix.vn/threads/asus-x552mj.24153/
- Mine is the 4 GB only with a memory slot version ( NO Onboard)
The PC all off a suden shut down, and then keeps blinking the Power LED, Wireless Led and Num-lock, the sequence is always the same, " Power led", then next at the same time " wireless led and num lock" and is always doing this. when the dows a sequance, seams to try to inicialize video, as i see the screen flicker but with no backlight
Tried first the normal, that is to take the batery off, press power button 60 seconds and then when that does not work took the bios batery out.
Still makes the same...
Tried to flash the Bios version available for it here on the site, still the same result...
Checked for any short on the board on any power component but no short...
Can someone give me a help?
Best Regards Samuel Antunes
