ASUS Q170M-C
BIOS Q170M-C-SI-1802
Schematics Asus Q170M-C RG-Vinafix
- CPU
Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
Supports Intel® 14 nm CPU
* Refer to www.asus.com for CPU support list - Chipset
Intel® Q170 - Memory
4 x DIMM, Max. 64GB, DDR4 2133 MHz Non-ECC, Un-buffered Memory
* The maximum memory frequency supported varies by processor. - Graphic
Multi-VGA output support : HDMI/DVI-D/RGB/DisplayPort ports
- Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
Supports up to 3 displays simultaneously - Expansion Slots
1 x PCIe 3.0/2.0 x16 (x16 mode)
1 x PCIe 3.0/2.0 x16 (max at x4 mode)
1 x PCIe 3.0/2.0 x1
1 x PCI - Storage
Intel® Q170 chipset :
6 x SATA 6Gb/s port(s), gray,
Support Raid 0, 1, 5, 10 - LAN
Intel® I219LM, 1 x Gigabit LAN Controller(s) - Audio
Realtek® ALC887 7.1-Channel High Definition Audio CODEC *1
- Supports : Jack-detection, Front Panel Jack-retasking - USB Ports
10 x USB 3.0/2.0 port(s) (6 at back panel, blue, 4 at mid-board)
4 x USB 2.0/1.1 port(s) (2 at back panel, black, 2 at mid-board) - Special Features
ASUS 5X Protection II :
- ASUS ESD Guards - Electrostatic discharge protection
ASUS Exclusive Features :
- AI Suite 3
- Ai Charger
- Anti-Surge
- Mobo Connect
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2+
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS UEFI BIOS EZ Mode
- Push Notice
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
TPM IC Onboard
Media Streamer - Operating System Support
Windows® 10 , 64bit
Windows® 8.1 , 64bit
Windows® 7 , 32bit/64bit *2 - Back I/O Ports
1 x PS/2 keyboard (purple)
1 x PS/2 mouse (green)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
6 x USB 3.0 (blue)
2 x USB 2.0
3 x Audio jack(s) - Internal I/O Ports
1 x MONO out header *3
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
1 x LPT header
2 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
1 x Internal speaker connector(s)
1 x System panel(s)
1 x Chassis Intrusion connector(s)
1 x DIS ME jumper - Accessories
User's manual
I/O Shield
2 x SATA 6Gb/s cable(s)
1 x Supporting DVD - BIOS
128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information - Manageability
WfM 2.0, DMI 3.0, WOL by PME, PXE - Support Disc
Drivers
ASUS Utilities
ASUS EZ Update
Anti-virus software (OEM version) - Form Factor
uATX Form Factor
9.6 inch x 8.9 inch ( 24.4 cm x 22.6 cm ) - Note
*1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
*2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
*3: Use with amplified speaker is suggested.
Q170M-C-SI-1802.BIN.zip
Asus Q170M-C RG-Vinafix.pdf
