Apple A1466 820-00165 A
Discussion in 'BIOS Laptop' started by B4RDOCK, Aug 7, 2016.
Apple A1466 820-00165 A 5 5 2votes
5/5, 2 votes
  1. ThienBui
    ThienBui CEO Staff Member
    Dec 13, 2013
    58,979
    4,196
    MacBook Air 13" Early 2015 A1278 820-00165-02
  2. Adesh
    Adesh VIP PRO
    Feb 13, 2017
    72
    6
    thanks. but its not clear for components match. please upload hd images
  3. ThienBui
    Dec 13, 2013
    58,979
    4,196
    Unavailable
  4. tnj141
    tnj141 Well-Known Member
    Mar 21, 2018
    53
    3
  5. ThienBui
    Dec 13, 2013
    58,979
    4,196
  6. tnj141
    Mar 21, 2018
    53
    3
    thanx very much
  7. tnj141
    Mar 21, 2018
    53
    3
    but this bios is bad no display
  8. tnj141
    Mar 21, 2018
    53
    3
    unlock this one plz
  9. ThienBui
    Dec 13, 2013
    58,979
    4,196
    what? bios you send above not work ? send one photo displat password i check.
  10. johnninfor
    johnninfor New Member
    Mar 7, 2018
    9
    I backed up the original file of the machine I cleaned the region and ME, and after inserting the file into the machine again already clean and then it worked! But the keyboard and mouse only work in the boot, when the system opens no longer work, can you help me?
    A1466 - 2015
    820-00165-A
    10.0.35.1012
  11. ThienBui
    Dec 13, 2013
    58,979
    4,196
    you need send i file bios old no any edit. Note you not need clear me where use right BIOS old same macbook.
  12. johnninfor
    Mar 7, 2018
    9
    I did this, but after I use the same BIOS and have cleaned only the , the machine was slow and did not install the OS, so after cleaning the ME it works, but the keyboard and Trackpad do not work when the system opens.
  13. ThienBui
    Dec 13, 2013
    58,979
    4,196
    you need buy guide for we and get support problem unlock.
    https://vinafix.com/resources/how-to-remove-password-bios-apple-add-edit-serial-number.1209/
    How to remove password Bios Apple & Add, edit Serial Number
    Remove the password does not need new BIOS. ( Password BIOS or iCloud )
    vinafix.com
    same one BIOS can not slow. you use one BIOS another ???
  14. johnninfor
    Mar 7, 2018
    9
    [QUOTE = "ThienBui, post: 101929, membro: 6"] você precisa de um guia de compra para nós e receba o problema de suporte desbloqueado.
    vinafix.com
    mesmo BIOS não pode diminuir. você usa um BIOS outro ??? [/ QUOTE]
    Yes, I also found it strange, I already did several in the same way, just clearing the region of the, this and first time I see this, the machine was slow, so I cleaned the region ME, the BIOS and original of it would not have to confuse.
  15. johnninfor
    Mar 7, 2018
    9
    [QUOTE = "ThienBui, post: 101898, membro: 6"] você precisa enviar um arquivo bios antigo sem qualquer edição. Note que você não precisa me limpar onde usar o mesmo BIOS antigo mesmo macbook. [/ QUOTE]
    Did you move that file or is it the same way?
    #135 johnninfor, Dec 29, 2018
  16. ThienBui
    Dec 13, 2013
    58,979
    4,196
    Inbox
  17. johnninfor
    Mar 7, 2018
    9
    I'm sorry, I didn't know! I am using the translator because I do not speak fluent English, I will send you the file unchanged when you can.
  18. ThienBui
    Dec 13, 2013
    58,979
    4,196
    file i send above have problem what ?
  19. johnninfor
    Mar 7, 2018
    9
    I'm not in my job now, the machine is there, now only after the holiday.
  20. ThienBui
    Dec 13, 2013
    58,979
    4,196
    Not working why there are so many problems if outlined above. waste time,
    You should only contact me when I try all BIOS and where in job... :(
Loading...
Similar Threads - A1466 00165 Forum Date
A1466 820-00165-A BIOS Laptop Apr 23, 2017
Macbook Air 13 inch A1466-EMC 2925-820-00165-A-Early 2015 BIOS Laptop Jan 4, 2017
Apple A1466 820-00165-02 2015 BIOS Laptop Jun 24, 2015
Apple A1466 Schematic Laptop Dec 17, 2018
A1466 BIOS Laptop Oct 15, 2018
Tags:
    • Whatsapp: +84919476686
  • Vinafix
