110-17IKB Schematics and BIOS (ideapad) DG710 NM-B031
110-17IKB Laptop (ideapad)
DG710 NM-B031 BIOS
Schematics Ideapad 110-17IKB LCFC DG710 NM-B031 r0.1.pdf
boardview Lenovo Ideapad 110-17IKB LCFC DG710 NM-B031 Rev 1.0 BoardView.tvw
subbaord
cds2f_NSA911R10-0329-View tvw
cds2f_NSA912R10-0329-View tvw
CG721_DB_LED_20160325.pdf
CG721_DB_ODD_20160325.pdf
UC3.bin.zip
25LQ64.BIN
ITE_8586.bin
cds2f_NSA911R10-0329-View tvw.zip
cds2f_NSA912R10-0329-View tvw.zip
hi
i need bios v110-17IKB 80V2
DG710 NM-B031
your bios is not working
OLD BIOS IN ATTACH
please repair old bios
I used this bios and the laptop works, but I have a problem with turning it off. After turning off, the laptop turns on by itself after a few seconds. Can you help me ? Ideapad 110-117ISK DG710 NM-B031 rev 1:0
I just need to know the difference between the old BIOS and the new BIOS and I'll figure out the problem
unfortunately I do not have the old batch, the memory was empty I also cleared the ME region but that didn't solve the problem either
so the problem is not really from the BIOS if there are two other BIOS with the same problem that indicates the BIOS is ok and you need to check the hardware.
I need help I have lenovo 110-17acl board cg 721 nm-a911 rev 1.0 starts and stops immediately before it did not start at all I replaced pu501 and I wrote the bios now I measured the voltages pl401-3.3v PL402 5v constantly the others appear and disappear immediately PL501 1.3v PL1003 1.5v Pl1001 0.8v Pl602 0.9v Pl601 1.8v
you want I help what ?
