Music VolumeShaper 4 AU VST 2015-05-08
Mac OS X 10.5 or later
    Courtesy of DOA
    * Check installation.txt and registration.txt for details
    VolumeShaper is a plugin for shaping and automating the levels of any audio signal. From signature pumping effects to extreme gating, from tempo-synced stutter to precise sample-shaping, VolumeShaper provides a wealth of creative musical effects with a visual approach to volume.
    New in version 3: A precise oscilloscope for helpful visual control, plus an option to trigger the LFO via MIDI notes.
    Fresh Approach to Volume
    Whether you're composing or mixing, VolumeShaper gives you a creative, intuitive way to shape level. Some examples of what you can do...
    The ducking effect
    Essential for modern mixes, the well-known ducking/pumping effect of sidechain compression creates extra rhythmic drive and provides space for the kick drum in the mix. VolumeShaper gives you this same effect with absolute control — just draw the sound you want.
    Define your audio loops
    VolumeShaper's new oscilloscope displays the incoming audio, helping you to precisely define audio levels. In a drum loop, regulate levels for snare and hi-hat etc with just a few clicks. Or edit unwanted notes out of a loop. From smooth bezier curves to hard cuts, you decide. Trance-gate
    VolumeShaper makes it easy to draw smooth, musical curves. And if you prefer hard steps, you can do that, too, for a trance-gate effect. Either synced with your host sequencer, synced to the frequency of the played note, or running freely at ranges from 0.02 Hz up to 5.24 kHz.
    Audio destruction
    Run VolumeShaper's LFO fast, up to the audible range, for punishing bit-crushing effects. Or set the LFO to the frequency of the MIDI notes that you play for ring modulation effects.
    System Requirements
    2 GHz Intel CPU
    Supported formats:
    VST, AU, RTAS (Pro Tools 8 and higher)
    32- and 64-bit
    Version: 2015-05-08
