USB-C PD 3.1 EPR - Phần 7: 40 IC và họ linh kiện 28/36/48 V
EPR mở rộng USB-C từ 100 W lên 140 W (28 V), 180 W (36 V) và 240 W (48 V), tối đa 5 A. Danh mục này tách controller, cable marker, protection, VBUS conversion, battery charger và adapter power stage.
1. TI EPR controllers and complete sink-side signal chain
3. Infineon adapter and high-voltage MCU companions
Mã/họ
Vai trò
Mức EPR
Lưu ý sửa chữa
EZ-PD PMG1-B1
Battery-charge controller with PD MCU
USB-C battery systems
Programmable high-voltage MCU
EZ-PD PMG1-S0
High-voltage USB-C PD MCU
Sink/source control
External power conversion
EZ-PD PMG1-S1
Power products
Firmware-defined
EZ-PD PMG1-S2
High-voltage USB-PD MCU
Power products
Firmware-defined
EZ-PD PMG1-S3
Power products
Integrated analog resources vary
EZ-PD PAG2-PD
USB-C PD adapter controller
Modern adapters
Secondary-side policy
EZ-PD PAG2P
Primary-side adapter controller
AC/DC conversion
Not a notebook battery charger
EZ-PD PAG2S
Secondary-side adapter controller
USB-C output control
Pairs with primary controller
4. ST EPR, embedded-UCPD and protection ecosystem
Mã/họ
Vai trò
Mức EPR
Lưu ý sửa chữa
ST-ONEHP
Integrated digital AC/DC + PD controller
140 W, 28 V/5 A
Adapter/source-side EPR
ST-ONE
Digital USB-PD power controller
Adapter platform
Source-side power conversion
TCPP01-M12
Sink port protector
PD 3.1 SPR companion
Not 48-V EPR protector
TCPP02-M18
Source port protector
Up to 100-W class protection
TCPP03-M20
Dual-role port protector
Bidirectional power path
STM32G0 UCPD
MCU family with embedded PD controller
EPR messages supported
MCU + external protection
STM32G4 UCPD
Digital power applications
STM32U5 UCPD
Host/policy implementation
5. EPR-rated protection and conversion building blocks
Mã/họ
Vai trò
Mức EPR
Lưu ý sửa chữa
NX48P0407
48-V CC/SBU protection IC
USB-PD EPR
NXP short-to-VBUS protector
NX30P6093A
High-voltage USB-C power switch
Bidirectional VBUS
Power path only
NCP81239
Four-switch buck-boost controller
Variable USB-C VBUS
Converter, not battery CC/CV
NCP81599
Bidirectional buck-boost controller
High-power USB-C
Source/sink conversion
FUSB3307
Programmable PD source controller
High-power adapter
Verify EPR profile support by design
STPD01
Synchronous buck converter
USB-PD source VBUS
Pairs with PD controller
MasterGaN1
600-V GaN half-bridge power stage
140-W EPR adapter reference
AC/DC power stage
L6563S
PFC controller
Mains-side companion
6. Điều kiện để vào EPR
Nguồn, thiết bị và cáp phải hỗ trợ EPR; cáp 5 A EPR có e-marker phù hợp.
Cổng bắt đầu ở SPR rồi trao đổi capability và vào EPR mode trước khi yêu cầu 28/36/48 V.
AVS cho phép điều chỉnh 15-48 V theo bước 100 mV trong giới hạn profile.
CC/SBU và VBUS protection phải chịu được lỗi chạm áp cao; linh kiện SPR 22-24 V không tự động phù hợp 48 V.
7. Đo kiểm thực tế
Kiểm tra 5 V mặc định → e-marker/VCONN → PD traffic → EPR_Mode → PDO/AVS → VBUS trước và sau eFuse → buck-boost/charger → VSYS/BAT. Nếu chỉ dừng ở 20 V, lỗi có thể do cáp, firmware profile hoặc protection rating chứ chưa chắc do charger.
Cảnh báo: 48 V trên USB-C đòi hỏi khoảng cách, MOSFET, tụ, TVS và dụng cụ đo phù hợp. Không thay port protector 24 V vào đường EPR 48 V.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
