Utilities uNetCams Multicam Monitor 2.1.0
uNetCams cho phép bạn theo dõi nhiều video và audio trực tuyến...
    5.74 MB
    Name: uNetCams: Multicam Monitor
    Version: 2.1.0
    - enhanced performance
    - support iCloud, Google Drive, Dropbox
    Courtesy of C.O.R.E
    uNetCams allows you to monitor multiple live video and audio feeds directly from network cameras (1000+ models of network cameras from 100+ manufacturers) and built-in/FireWire/USB webcams with top notch performance and speed.
    * Main Features
    ▶ Up to 100 cameras can be configured
    ▶ Direct access to audio and video streams from cameras. No NVR or 3rd party server is required
    ▶ Audio support - See details at www.ubntek.com/supportedcameras/audio.html (not all models)
    ▶ 2 Way Audio (Push to Talk)
    ▶ Recordings can be scheduled to start and stop multiple times on any particular day, or the same time periods can be set for multiple days simultaneously
    ▶ Export event recordings in the specific time duration to one video clip
    ▶ Simply playback video from scheduled, event recordings by daily or hourly search
    ▶ Automatically record videos with audio by in-app noise and motion/face detection
    ▶ Support iCloud, Google Drive, Dropbox
    ▶ Monitor multiple branded cameras and webcams separately located in a single app for easy access
    ▶ Easily view multiple feeds simultaneously on a screen with layout controls (1, 4, 8, 9, 16 layouts)
    ▶ Live video viewing of up to 16 feeds at a time or full screen
    ▶ Friendly navigate back and forth between multi cameras screen
    ▶ Pan and Tilt controls up to 8 directions
    ▶ Presets control up to 8 positions
    ▶ Patrol preset positions or vertical or horizontal (if applicable)
    ▶ Switch IR-LED illumination for night vision on/off
    ▶ Activate or deactivate output port for connecting external devices
    ▶ Set the resolution of video image (if applicable)
    ▶ Enable or disable Aspect Fit
    ▶ Quickly and easily add new models with reload button
    ▶ Clone easily camera settings
    ▶ Exchange setup file between the Mac devices or import it from iOS devices via email attachment
    ▶ Reorder camera lists
    ▶ Enables setup without username and password for a public camera anywhere in the world
    ▶ Compatible with Dynamic DNS services
    * Supported IP Cameras
    ABS, Abus, ACTi, Agasio, AirLive, Airlink, Airsight, Alecto, Allnet, American Dynamics, Apexis, Arecont, Asante, Asoni, Astak, Axis, Axis Encoder, Blue Iris, Bluecherry, Bosch, Brickcom, BSTi, Camyio, Canon, CIPCAM, Cisco, Clairvoyant, CNB, Compro, Coolcam, Corum CCTV, Cybernova, Dahua, DBpower, Dericam, Digi-Lan, Digital ID VIEW, Digitus, DiViS, D-Link, EasyN, EasySE, Edimax, ELE Technology, Elro, Eminent, ES(Eye Sight), Etrovision, Evocam3, Eyespy, ezCam, Foscam, Fuho, Gadspot, Genius, Grandstream, GrandTec, Hama, Hawking Technology, Heden, Hikvision, Hootoo, Huacam, iBaby, ICY BOX, Instar, Insteon, Ipux, IQeye, Kadymay, KaiCong, Konig, LevelOne, LILIN, Linksys, Loftek, Logilink(Hama), Lorex, Loxone, LUPUS, Luxon, Maginon, Marmitek, MayGion, Mobotix, Netbotz, NetMedia, Novibo, Orite, Panasonic, Panogenics, Planet, Planex, SaveOnSecurity, Sercomm, SeQurecam, Sharx, Shixin, Showtec, SitCon, Sitecom, Smar Industry, Smart Teck, Smarthome, SMC, Sony, SparkLan, Sricam, StarDot, Storage Options, Sunluxy, Swann, Tenvis, Toshiba, Tp-link, Trek, TrendNet, Trust, Ubiquiti, UCam247, Uvision, Vilar, Vivotek, Vivotek Encoder, Vstarcam, Wanscam, Wansview, WatchBot, WatchMeIp, Webcam123, WinStar, Wirepath, Xenta, Xvision, Y-cam, Yawcam, Zavio, Zmodo, ZyXEL, 3S Vision, 4XEM, 7Links
    * Supported USB/FireWire/Built-in webcam (refer to the web page)
    - Check first if USB/FireWire/Built-in cameras properly works on the Mac and Windows
    - Select a model as uWebCam -> Mac or Windows
    - Connect between uWebcam and uNetCams
    * Note
    Before you can control your camera(s) remotely over data networks, you need to setup your router to allow incoming traffic. For security reasons, routers don't normally allow external traffic into your local network. You should read your camera’s setup manual regarding port forwarding. For more information, please see www.portforward.com or www.dyndns.org
    If you have any suggestions or other comments, click the Help menu.
    7aacffa61b228dcc93f843c57a1af1d9.
    8a6be3b38e38790d218ca3803d30c127.
    0ef252fc28e68c550dfda29bc70dcc60.
    16c04367772e033b59100f1954eb1641.
    ab84840cf5258cfcc88b3773d8eb7cd5.
